spraying metallic celluose
Discussion in 'Bodywork' started by Marku, Sep 17, 2017.
  1. alabbasi
    alabbasi MB Enthusiast
    1,477
    Feb 18, 2008
    You think? :)
  2. wu56Shoozz
    wu56Shoozz MB Enthusiast
    1,983
    Jun 17, 2016
    You'll need a passport to get over the Wall..
    Car:
    MB Vito 111CDi / W203 C Class Saloon 320CDi Avantgarde
    Wow! What a job... very nice. Can I ask what epoxy you used as a rust inhibitor??
  3. RaceDiagnostics
    RaceDiagnostics Active Member
    251
    Apr 29, 2010
    Dunfermline
    Car:
    450SL XK8
    I use Lechler LS107, "Bi-component epoxy primer with zinc phosphate and high anti-corrosive power."
  4. wu56Shoozz
    1,983
    Jun 17, 2016
    Car:
    Nice! Cheers for that.. I use Epoxy 121 hence my question..
  5. KeithJG
    KeithJG Active Member
    599
    Nov 5, 2014
    Dover, Kent
    Car:
    Vauxhall Tourer
    1969 Lotus Cortina.jpg View attachment 72298 View attachment 72298
    This was my Cortina Lotus from 1969....the top lacquer peeled on this and ended up being sprayed Daytona Red with a vinyl roof.
    I thought it was the change over to Acrylic from Cellulose paints and the adhesion or lack of was due to the electrolysis of the paint and vehicle being sprayed was different so it did not adhere as it should of done.
  6. RaceDiagnostics
    251
    Apr 29, 2010
    Dunfermline
    Car:
    450SL XK8
    I use 121 or similar on the chassis, inner wings and suspension parts and the LS107 on body parts.
  7. OP
    OP
    Marku
    Marku Active Member
    754
    Dec 18, 2012
    Car:
    Viano Ambiente 2.2CDI W639, S-Class 450SE W116
    Think I have solved it. Better control with the new gun. Tighter fan spread and less volume with about 15% more thinners in the clear coat. I thought all Mercedes had a clear coat? Any way mine is cellulose and decided to use it again because I thought it would be more forgiving. As I said was getting really well and getting a good finish that did not need flatting down and polishing but have now bought a polishing machine which does give a glass like finish. Did think you could not mix paint types and certainly not put a 2K finish over cellulose as I was trying to avoid going back to metal. Ended up having to do that but gradually learning.
  8. Robdata
    Robdata Active Member
    74
    Apr 14, 2014
    Oxfordshire
    Car:
    C63 2013
    This car looks awesome. My friend used to have one like this. That was my first ride in a merc. Lovely car but rust was allways a big issue
Share This Page
