Some of you may recall us doing the ecu reset well the SPPRINTBOOSTER elliminates the need for you to do that and stays reset all the time.
thus making the car undrivable on part throttle.
Bring back the old throttle cable i say .
It doesn't make the car undriveable on part throttle. I've had one fitted to my car for the past 18 months.
Personally it removes the lazy lag you get when driving a Merc, and it certainly makes the car more fun to drive
The lag is there for a reason, everyday driving steer well clear sprint booster will compromise your drive and safety
when first fitted there can be a few hairy moments due to the difference it makes ( first day I had mine fitted I nearly rear ended a car as I went to overtake )
but you soon get used to it and adjust your pedal inputs accordingly,
In Fact I'd say for everyday driving it's probably better with whatever inputs you make on the pedal getting an equivalent response from the throttle.
even parking's a piece of cake
Does make a difference I agree but for performance, security and driver training it actually slows you down (see earlier post) so not for me I'm afraid. People relate sharper throttle response to more speed and more progress but it's not the case.
your absolutely right it doesn't add any performance and I also found if anything it made the car slower.... at least from a standing start
but tbh I never considered it a performance mod, I bought it purely to overcome the throttle lag which I personally find annoying and unnecessary, and it does this very well.
I think some people are under the misconception that it makes the throttle pedal more like a hair trigger with even a slight push giving an instant surge forward ,which it doesn't,
you get the same response just with less delay, and the car is just as controllable as before if not more so,
it just takes a bit of getting used to not having to wait a second or 2 for something to happen when you press the pedal
I would totally agree with your comments I think it is peoples misconception of what this device does is actually the main problem.
If it works for you then great and I suspect it may also be better on some cars than others, thats why the dissemination of knowledge on this forum is so important it lets you sort out the fact from the fiction
If you want to know more about what it actually does - see here
Incidentally, if I were permanently installing this device in my car, I would want the Sprint Booster to have two completely independent amplifiers. Why? Mercedes wisely used two independent accelerator pedal position sensors for the ECU to sample. In this manner, a single point of failure can both be detected by the ECU (a check engine light and code) and worked around (driven normally). If the Sprint Booster does not use independent circuits, a single point of failure could affect both outputs, rendering the car inoperative or telling the ECU to floor it, neither of which might be detected by the ECU as a fault. This is unlikely perhaps, but not impossible.
