lawrence7
Hi my sprinter has developed a woopsy although everything seems to be working ok I have no dash warning lights none clocks work, and no mileage display. I HAVE PUT SECOND HAND DASH, STILL NO CHANGE. HAVE HAD FUSE BOX OF AND CLEANED TERMINALS CHECKED PLUGS AND FUSES. is there any wires that are around the passenger side of engine bay that could case this as found wire with big gromit on near starter motor might be unrelated
this started about september with the odd failure I STRIPPED AND RECONNECTED A WIRE ON BATTERY SEEMED OK FIXED THE WHILST BEING PARKED UP OVER WINTER BATTERY DIED NEVER WORKED SINCE BUT TURN ON CAN HEAR GLOWPLUG RELAY KICK IN THEN WILL START STRAIGHT AWAY , ALL LIGHTS IE SIDE MAIN AND HIGH BEAM WORK EVERYTHING JUST NOTHING ON DASH A TALL , The arms all work strange like no power to any of it please help if you can
LAWRIE7
NEWBE
LAWRIE7
NEWBE
