Sprinter 315
Chugger
England
Sprinter 315
hi all I have a van problem and looking for help
van is 2007 50k miles runs great but takes about 15 seconds of cranking to start battery is perfect
many thanks Bob
sounds like you have a leak on the fuel side and its drawing in air and the fuel has probably run back to the tank so it has to pull it all back up hence taking time to start,you need to check fuel connections for split pipes etc
Fuel pressure sensor on the common rail could be the problem. A star scan would give you the live data for the pump pressure Etc.
hi very many thanks for your suggestions
