Sprinter w906 goes in to limp mod and EML comes on
Paddyfinn1968
Devon
Sprinter w906
Hi I have a 313 sprinter w 906 and it keeps going in to limp mode when driving under load and the EML flashes till the ignition is turned off the the light stays on ,it sounds like its sucking air when it’s at the top of the revs range but I can’t see any splits in the pipes or any obvious damage so not sure where to look any help would be appreciated cheers Paddy
Unless you can see an obvious split intake or boost pipe you take need to get the codes read......otherwise anything anyone says on here is a best guess.
I always keep a Bluetooth OBD adapter in all my car and have TorquePro on my phone for just such events
Unless you can see an obvious split intake or boost pipe you take need to get the codes read......otherwise anything anyone says on here is a best guess....
+1.
Aka parts darts.
