sprocket/chain check
thamesc180k
New Zealand
04 c180K
hi all, i plan to remove the valve cover to check the cam sprockets for wear and the chain for slack.
how can one tell if the chain has stretched?
now ive read a post that says early engines, the sprockets wear, later engines the chain tensioner fails. is this true?
how do you class an early engine against a later one?
i havent noticed any rattle on start up as its noisy anyway, similar to a diesel (chattering noise) and seems to be tensioner bearing? im going to replace the two pulleys anyway, but i theres rattle for a second or two on starting from being just run. if this is a chain tensioner leaking down, surely it would do it on a cold sart too?
Any advice would be great thanks and does this hose hold coolant in my pic?
thankyou Karl
thankyou Karl
Yes that’s a coolant pipe , the left hand end of that pipe where it meets the engine is the thermostat.
thankyou for that , im guessing ill drain the radiator a tad to remove it if i end up replacing something?
that begs the question... where is the temp guage? in the menu on the dash?
its an 04 w203, m271 engine of course.
I don't know when the switchover occurred exactly, but on a general note, W203s with the M271 1.8L Kompressor engines are 'early' engines, while the M271 1.8L and 1.6L Turbo engines on the W204s are the 'later' engines.
If your car is a 2004 model, then it is certainly an early engine, because the M271 was only introduced in the W203 a year earlier, in 2003.
ok thanks thats good to know, cheers
These photos will give you a good idea what worn sprockets look like:
oh yes they are certainly worn! the timing mark that isnt lined up is a stretched chain i understand?
today i removed the valve cover and inspected the sprockets, timing marks, and chain and they are in very good condition and spot on, so stoked (happy). will reassemble and bought a new valve cover for $31 NZ (WHAT A SCORE).
Thanks for the information.
change the conversation, but do you know if the c200 (2.0 ltr) uses the same front shocks as the c180 ,same model/shape as mine?
Thanks again Karl
To check it properly you need to set the timing to TDC and see if it lines up.
