Sqeeling/ possibly sticking brakes
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by Cj320cdi, Jun 24, 2018.
  1. Cj320cdi
    Cj320cdi Active Member
    93
    May 5, 2018
    Notts
    Car:
    320 cdi 2003
    Hi, back yet again but with a new issue...... recently changed the front discs on my 03 e class 320 cdi. But have the same issue of squeeling front brakes and at various speeds it’s on and off as if the discs are warped but obviously not as they are NEW ! I would of thought by now that the pads would have evened themselves out by now but doesn’t sound like it ???? Also I think especially after quite hard braking it feels like they stick as from standstill sometimes the car seems to roll better sometimes than others ????
  2. OneForTheRoad
    OneForTheRoad Hardcore MB Enthusiast
    1,677
    Apr 20, 2015
    uk.
    Car:
    ford kuga.
    Did you polish the hub face first before fitting new discs ?
  3. OP
    OP
    Cj320cdi
    93
    May 5, 2018
    Notts
    Car:
    320 cdi 2003
    No as they have a protective oil or something on them ? And never heard of polishing a disc ??
  4. CarlPea
    CarlPea Hardcore MB Enthusiast
    196
    Apr 23, 2017
    Car:
    E63
    Did you remove the rust protective coating, if any, off the disc face with brake cleaner?
  5. OneForTheRoad
    1,677
    Apr 20, 2015
    uk.
    Car:
    ford kuga.
    I said hub face not disc face . lol.
  6. OP
    OP
    Cj320cdi
    93
    May 5, 2018
    Notts
    Car:
    320 cdi 2003
    yep so you did....... I totally misread that 1st reply ! DOH !
  7. OP
    OP
    Cj320cdi
    93
    May 5, 2018
    Notts
    Car:
    320 cdi 2003
    No haven’t cleaned any surface so will have a look in a bit
  8. OneForTheRoad
    1,677
    Apr 20, 2015
    uk.
    Car:
    ford kuga.
    Take your time
  9. DSM10000
    DSM10000 MB Club Veteran
    5,563
    Jul 12, 2011
    Near Salisbury
    Car:
    E32O CDi Sport, MX5 1.8 Sport, RR 4.2 SC
    Why do you think that the noise is caused by warped brakes? Are there vibrations under braking as well?
    You only mentioned replacing discs, did you use the old pads or new ones ?
  10. OP
    OP
    Cj320cdi
    93
    May 5, 2018
    Notts
    Car:
    320 cdi 2003
    The old disc s were warped as I found out just 2 weeks after buying car...... was horrendous wheel wobble but squeeling just the same but old pads have plenty ware left so kept them.
  11. DSM10000
    5,563
    Jul 12, 2011
    Near Salisbury
    Car:
    So the new discs are not causing wheel wobble so why assume they are warped?
    The noise is almost certainly due odd wear patterns on the old pads trying to contact against the new discs, it is recommended that you replace pads when replacing discs. Did you remove the pads from the caliper, clean the caliper and apply new copper-ease or similar paste to the pads?
  12. CarlPea
    196
    Apr 23, 2017
    Car:
    E63
    If there was a coating then you could have contaminated the pads. you need to remove the pads and use sand paper to create a fresh surface to work with.
  13. AMGeed
    AMGeed MB Club Veteran
    10,892
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2004 W211 E55K ///AMG
    ^ The OP needs to throw those old pads in the bin and get some new ones.
    I was told you never replace the discs without new pads as well.
    I would also check the pistons in the calipers are moving freely and not sticking.
    And when the caliper is off, remove the disc and ensure the hub mating face is spotlessly clean.
    Cj320cdi likes this.
  14. OP
    OP
    Cj320cdi
    93
    May 5, 2018
    Notts
    Car:
    320 cdi 2003
    Hubs are now cleaned up. There is no wheel wobble with the new disc s just the squeeling issue but I will see if they do it still tomorrow when I nip to lincoln. And no I haven’t cleaned the Calipers but did put paste behind the pads which do sit straight within the calipers but maybe aren’t levelling up to the disc s..... if the noise continues I will purchase new pads next week. Just a shame as the current pads have atleast 1/2 life left !
  15. OP
    OP
    Cj320cdi
    93
    May 5, 2018
    Notts
    Car:
    320 cdi 2003
    Well after giving the hubs/ disc a good clean etc, took a trip to newark and back as lincoln was cancelled lol but pleased to report no more sqeeling !
    AMGeed and OneForTheRoad like this.
  16. OP
    OP
    Cj320cdi
    93
    May 5, 2018
    Notts
    Car:
    320 cdi 2003
    Lol damn squeeling started again ! Hopefully get them off again and really scrubbed up tomorrow !
  17. DSM10000
    5,563
    Jul 12, 2011
    Near Salisbury
    Car:
    Change the pads and stop wasting your time.
    OneForTheRoad and Smart320 like this.
  18. OP
    OP
    Cj320cdi
    93
    May 5, 2018
    Notts
    Car:
    320 cdi 2003
    Yes come to that conclusion today but thanks for the help and advice, once again !
  19. OneForTheRoad
    1,677
    Apr 20, 2015
    uk.
    Car:
    ford kuga.
  20. OP
    OP
    Cj320cdi
    93
    May 5, 2018
    Notts
    Car:
    320 cdi 2003
Share This Page
