Hi all, I have recently bought an April 2000, CL500 (W215) and need some help with the following issues, please:-
'SRS' Warning light issue
1) With the engine up and running, the SRS dash light remains permanently, 'ON'.
2) Also, with a person sitting in the passenger seat, the seat-belt when plugged-in, tensions/acts normally whilst the ignition is OFF/Engine not running ...... On 'start-up', the seat-belt tension releases, remains so and the belt can be pulled out further very easily.
Driver's window automatic wind-up issue
1) On initial unlocking, opening of the driver's door, both driver's-side windows open slightly. On entry and closure of the door, the windows remain slightly down. If the door is opened again immediately and closed again, the windows go up OK. Another way to close fully on entry is to then turn the ignition 'ON' and use the door window button to close it up.
The car is due an MOT at the end of May 2013, so I'd much appreciate your help and contributions, please ...... Thanks in anticipation, Bob
