Srs Fault
2swift4u
00 E300TD
My SRS light on my 2000 E300TD does not go off i have sopken to my mechanic and he says its the N/S SEAT SWOB (SRS) FAULT what is this and where is it located is it a big job?
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
if it is that fault then: yep, its a pad that goes under the leather..... seat out, taken apart, leather taken off seat, pad inserted in th epassanger seat.... you could buy a pad (£20) and then connect it to the connecter (RED) under your seat to see if that rectifies your SRS fault......
hope this helps....
OP
OP
2swift4u
2swift4u
00 E300TD
Thanks a lot for your reply i might give it a go but i dont no much how do i take the seat out
KillerHERTZ
Administrator
Staff member
Cambs
G55 AMG Kompressor
Mine goes off after about 3mins, would this be the same fault?
OP
OP
2swift4u
2swift4u
00 E300TD
No mine stays on most of the time but now and agian it flickers
