hi all
any help or info appreciated
2 days ago i was idle with the engine running for 1 hour at least.
i a message popped up on the dash
stop vehicle leave in park and leave engine running.
now after a bit of research it seems its the auxillery battery gone or on its way out.
there are no symptoms
as in everything works absolutely fine. all 12v ports work with no defect
lights work fine
car doesnt struggle to start
but only the start stop light stays yellow and doesnt move over to green light which is activated
there are no others problems
wonder if anyone has had same issue and would know of a solution
lights work fine
