Star Xentry - How to view fuel trim?
golf2
Berkshire
W211 E320 CDI
Hi chaps,
My E320 cdi OM648 just failed MOT on emissions. The smoke test gave an average value of 1.2 and the plate value is 0.6.
I've treated the fuel system with Millers Ecomax and given it a good thorough drive with plenty of high RPM acceleration but it hasn't improved at all.
I have Star diagnostics so would like to check the function of the MAF sensor. Does anyone know how to view the live fuel trims or airflow readings using Star? I can't seem to find these values?
Many thanks in advance.
Tom
clk320x
Hardcore MB Enthusiast
East Midlands
W212 E250 CDI Sport - S211 E320 CDI Avantgarde - S203 C32 AMG
What’s the mileage?
mersum1es
Finland
W212, C219, W220
W211 is DAS car.
Under CDI unit go measurements and thet select 'check engine on idle' (can't remeber exact menus in english). Injector correlation values should be found under check engine run too. You can also try via 'list of checkings'. Practice in simulation mode.
Edit: could be boost problem too...
clk320x
East Midlands
Hi chaps,
Tom
What happened in the end out of interest? Noticed you never updated the thread :)
OP
OP
golf2
golf2
Berkshire
W211 E320 CDI
Sorry I'd completely forgotten about this! I should have set up email alerts.
The MOT tester managed to get it to pass eventually when the engine was hot but only just. I've actually just found out I had a leaking injector so that may have been a contributing factor. It'll be interesting to see how it gets on at it's next MOT now the injector is fixed.
It's done over 170k miles but has been very well maintained by Mercedes most of its life. It was remapped at the time of MOT fail but I've since had the remap removed to be on the safe side. It's passed 2 or 3 previous MOT's with the remap though so doubt that was causing it.
clk320x
East Midlands
What were the symptoms of the injector leaking?
OP
OP
golf2
golf2
Berkshire
W211 E320 CDI
