Viruslover
- Sep 1, 2015
- W211 E200K 2005 123' km
Hi there
I've had a problem for a while with my car, and seems like no dealers have managed to find out yet
Every morning when I start it, it cranks for a few times before starting and idle is a bit high and takes time to go down to 900-1000 but then it moves slightly up and down. Veeery slightly. Very rarely, the engine has one big misfire or something on cold start.
You can really feel it when you sit in the seat.
The engine runs smooth and it doesnt lag or jerks, but it has really lost power. I can kickdown and it goes very slow forward compared to a year ago. Gas mileage is also worse
My friend said it came gas smell from the hood on warm starts.
When the car is warm it cranks a lot before it wants to start.
I have a tick sound from the engine, rear part of the engine. I hear it best when the car is warmed up.
The dealers have digged deep looking for fault codes and printed me some paper showing that there is absolutely no code stored at all. Im so ******, i really wish it would throw a code. The dealers say this car is full of sensors everywhere and if it it was something wrong with the engine it would easily throw a code...
As far as I know they havent tested the fuel delivery system.
Engine also sounds louder than it did before when it ran like a champ. It has been low on power for a year now and im really tired of it
Can a bad battery or alternator cause engine-power problems in the car too? Other weird symptom is if I start it while its warm the tachometer takes almost 2 seconds after the engine has started to run before it jumps up to idle speed and i have a "brrrrrr" sound for a second after it starts to read. It looks and sounds really weird and NOT normal at all.
It seems most bad at lower rpm because on the highway it speeds up pretty fast if I drive in 80mph if i kickdown to speed up to maybe 100 mph.
Sorry for my bad english.
Thor
Thor
