I just start mine, no condensation no smell, on trickle charge best thing I ever bought
After storage, make sure the fluid levels are OK, nothing has leaked due to animals nesting in the engine bay and eating away.
Check electrical wiring for the same - animal damage.
Make sure you have some fresh fuel,
Ensure battery is well charged to give rapid start.
Switch it on and let it run.
Wrt interior smell, leave windows ajar by a finger. If the car is in a garage facing the sun, open doors/windows if safe to do so. Much more efficient than silica packs.
That's what I do & have done with various cars over the years. Always have something in hibernation during the winter. Stabil also what I use with a full tank of fuel. Works for meRegarding fresh fuel, I put a full bottle of STABIL fuel stabilizer into my tank, then fill her up and let car idle for 5 min for fuel circulation before I stored my car last autumn.
The E10 should be OK or not with Stabil fuelstabilizer used for ethanol blended fuels?
Stabils is an American brand of fuel treatment.
Never had that problem with a smell. Don't know if silica gel prevents it as it absorbs any moisture so may help. When colour changes, stick it on a heater in the house or microwave
As you car is in the garage leave the windows down an inch or so. Should prevent the smell. My car is not locked when in hibernation I don't see the point. If someone can actually get into the garage its then much easier damaging the locked car trying to get into it. This is what I use Amazonhttps://www.amazon.co.uk/FiNeWaY-REUSABLE-DEHUMIDIFIER-MOISTURE-ABSORBER/dp/B077K8BJW4/ref=sr_1_4?crid=29FVE6VUXW5JM&keywords=silica+gel+bags&qid=1647182045&sprefix=silica+gel%2Caps%2C1507&sr=8-4
About £10 & works fine
Silica beads are small, round balls of silica gel. While silica gel may sound like a soft or liquidy material, it is actually a solid form of silicon dioxide, a natural material found in the earth. These colorless beads are primarily used to control the moisture content of consumer goods. While many people mistakenly believe that silica gel is toxic, the gel itself is found in food and beverages. Silica beads are therefore only harmful when they are treated with dangerous chemicals that help to enhance their moisture-absorption properties.Are they suppose to be hard?
Silica gel is frequently found in small packets used to absorb moisture in clothing, electronics and other items.
The process of making silica beads starts when natural silicon is extracted from the earth. When silicon is exposed to the air, it oxidizes, resulting in a product called silicon dioxide. By adding sodium silicate to silicon dioxide, manufacturers can create silica gel. Depending on the conditions under which it is produced, this gel can take the form of tiny grains or larger silica beads.
Silica gel may be found inside pepperoni packets.
Silica beads are used in a number of manufacturing and household applications. They can be formed into glass or quartz to make countertops, tile, and other products. These beads also serve as a highly-absorbent form of cat litter, which is used in place of traditional sand or newspaper. Silica beads also are a common food additive, and are even added to water in some areas as part of the purification process. These beads are the primarily component in diatamaceous earth, which is used as a natural alternative to chemical pesticides.
Perhaps the most common use for silica beads is as a dessiccant, or dehumidifying material. Due to the highly porous nature of silica, these beads are a highly effective moisture absorption agent. They are added to packs of food, such as dried meats, as well as various types of medicine. Many clothing and shoe manufacturers add packs of silica beads to their products to prevent moisture damage during shipping or storage.
In its pure form, silica gel is essentially harmless. Despite this fact, packages of silica beads are often marked with dire warnings that the contents should not be consumed. Silica is frequently treated with highly toxic chemicals that can be deadly if consumed. For example, beads coated with cobalt chloride can cause both short and long term illness, while those treated with methyl violet can cause severe illness or death. While chemically treated beads are often colored to help identify them, this is not always the case, so consumers should never eat these beads.
Unless the inside of your car is like a rainforest you will not notice anything in 24 hrs. My car was Sorn'd in November when I put in my silica gel bag & I only had to "recharge" it once up to the end of March & it was not that bad.I've put one silica bag in the cabin yesterday.
Didn't notice any difference after 24 hours of use?
