JimE
Hi guys sorry if this is in the wrong section but I don't know where it should be...
I parked the car on the drive after work yesterday and today it wont start. Unlocks as normal, put the key in and it fires up then dies within seconds or else it turns over and doesn't fire. I work in the NHS in my local A&E so need to get to the bottom of this fairly quickly? At the moment I am going ot have to get it trailered to the garage and leave it with them unless there are things you guys can suggest I check? Battery has been on charge all day so its not a flat battery, I am thinking ignition fault or transponder?
Can anyone out help a poor NHS worker?
Jim
Jim
