television
Hardcore MB Enthusiast
With my serious hat on..... If the condensation is excessive then this would definitely be my first suspicion.
John
Is that the hat in the picture
John
John
I don't berlieve it...Is that the hat in the picture
If there's that much condensation then I'd think you must have water getting into the car somewhere.k, this was not a normal mist that would be found on the screen as per usual, thses were actually droplet of water that some had run down the inside of the screen due to there being so much of it.
I agree.
Did it rain your way last night?
Do you have a sunroof? - Check drainage pipes.
Was a door/window left slightly open? - check condition of door seals, check for damp carpets.
Failing that it might be a leak from the heater matrix.
Do you have a sun roof?Thanks Jeremy,
No rain, it was -4 DEG this morning, it took a good 10 mins to de-mist, misting was very dense, not your usuall thin stuff (MB!) before i could drive off. A/C was off on way home night before, to minimise moisture on condenser.
Yes, but haven't checked drain pipes - Good idea.
No windows or doors left open, door seals appear fine.
Carpets are dry, no smell of anti- freeze and water level not going down, so presume, matrix is ok.
I'll keep on scratching my head!
The drain pipe might be split or blocked.
Have you thoroughly checked the windscreen sill?
Water can creep in via a poor seal and then soak into the car's insulation, thereby creating the condensation.
If this water can be scraped, or squueged off then I'm positive you have a small leak somewhere. This might be a perished seal, or a small hole, but the condensation seems to much for natural causes.
How often is this condensation appearing? Is it only after rain?
Hi Glojo,
On my son's Golf I lifted up the rubber seal around the windscreen and found a small gap where it screen had not been correctly fitted. Water was getting into the car and then soaking into the in sulation on the A-pillar, which then at night caused a thick layer of condensation to form.
Good luck and remember....
That water is coming from somewhere.
Hi Glojo,
I will check sun roof drain pipe and all other areas you suggested.
I wouldn't say the water can be squeegied? off, but the mist is very dense.
Condensation seems to appear more when windscreen is frozen (OAT very cold) not just when it has rained.
Thanks for suggestions
