steering angle sensor
johnch121
c220 cdi
How do you reset the steering angle sensor I have had the steering wheel off to replace the indicator stalk and now have a steering angle sensor error?
Thank you
Should reset going from lock to lock twice with the engine running.
Then turn off
Restart , and the lights should be off.
Had that a few times on my old CLK
With the engine running and the car stationary in Park, simply turn the steering wheel from lock to lock a few times switch off and its cleared.:thumb:
Thanks for the reply I tried that a few times but it did not get rid of the error so what I did is take of the steering wheel (again) and turn the sensor around until it felt a bit tight and the turned it back about 3 1/2 turns put it all back together again and hey ho the error had gone.
