Steering Damper
GrahamC230K
Audi A3 & S4 quattro
For your reference....
When you start to get patterns like this on your drive way you know you have a leak!
Conclusion is a leaking steering damper - shown here (without leak).
Part is about £32 + VAT ish, so not expensive but apparently common to fail.
fuzzer
Glasgow
F25 X3 20d SE
Yup , mine failed on my 202 . Was replaced under warranty in order for the car to pass the MOT :)
OP
OP
GrahamC230K
GrahamC230K
Hmm.
Not really on for 63K easy miles is it. But at that price I'll not complain.
fuzzer
Glasgow
F25 X3 20d SE
Mine got changed at 34,000 , so you did not bad:mad:
OP
OP
GrahamC230K
GrahamC230K
Confirmed my damper was at fault.
With it removed, there was very little resistance left when compressing it and when near full compression a neat fine jet of oil shoots out of a hole!
The new part (sorry for blurry pic)
OP
OP
GrahamC230K
GrahamC230K
No. I think I caught it before it got too bad.
Limited Edition
Virginia Beach, VA USA
1993 190E (3)
I was told to change that every 60K miles. I have replaced mine in all three of my 190Es and my old C280. Replacing them got rid of the slight steering wheel shake.
Aletank
Liverpool,UK
I take it the're easy to fit ? Just a bolt either end is it ?
Obviously better on a ramp like Jimmy's :p
OP
OP
GrahamC230K
GrahamC230K
Indeed - spot on. As simple as that - need torque wrench to put bolts back in to correct tightness.
Philirv
Oxford
Mercedes Benz W124 E280 Auto
Hi Guys.
I don't know whether to feel good or bad, as I work for the company that makes these for MB.
Company is STABILUS.
Tee-Hee :bannana:
Philirv
Surf Blau
Stavanger, Norway
1984 Mercedes-Benz 190D
I remember replacing mine after buying the car - I couldn't feel any difference whatsoever! But for all I know it might help reduce shaking (if present) at motorway-speeds..
It should be due for replacement again soon if the changing-interval is supposed to be 60K Miles :D
Kinky
Berkshire
All sorts of odds n sods
I had mine replaced last week http://mbclub.co.uk/forums/showthread.php?s=&threadid=3230
And yes a very obvious difference - like a new car.
Admittedly mine had leaked dry! (but can't find any patches on the driveway or at work!).
And 128k on the clock - I don't know if the duff one was the original or a replacement.
K
