steering fluid
logman
south east
e55amg kompressor estate
Hi e55 amg w211 checked steering fluid level and is at bottom what fluid is needed is it auto trans fluid thanks
Get the right pas fluid . Some models do use ATF .And there are models that dont . The ones that dont use ATF you will need special Mercedes own type of power steering fluid.
There are some people that say ATF will be do ,,it wont do in place of the right MB pas fluid .
See if specification on ATF can meets MB specification should be OK
Thanks yes I checked spec and is fine shows mb quality its first time to top up in 11 years
