Steering judder on braking
Fredc63
Teesside
C63
I'm getting judder under braking on my 2011 C63. New front discs and pads fitted which helped but haven't cured the issue.
Any ideas?
Are you sure its from the front?
Could it be some worn steering/suspension joints?
Pretty sure it's from the front, can feel it when you apply the brakes coming through the steering wheel
Check the front end for play first.
The new discs could be warped?? Was the hub cleaned properly when they were fitted.
I'll check both the play on suspension and the hub. Cheers
Wondered if it could be a stuck piston on the caliper?
That may cause overheating and a warped disc. You drive it hard?
