Gulfstream2000
From about 40 - 55mph I have some steering wheel shimmy. ( SL55 )
Have gone through the usual route of balancing, alignment, checking for play in suspension etc ...
The only play I can find is in the classic wheel bearing play check, 12 o'clock and 6 clock leverage. You can hear a distinct clonk.
So setting up with dial gauge with .02mm end play ( parallel to axle), I can still feel quit a distinct clonk when grabbing the rotor at 12 and 6 and effectively twisting it
rather than the push / pull - parallel measurement.
* Note - if I tighten up the bearing considerably - there is no clonk, but I'm worried about too much rotational resistance.
My question is for those that have adjusted your bearings, do you feel any play with the 12 / 6 oclock twist check after ?
Thanks !
Thanks !
