Sticky throttle pedalon ML
nigel cross
Surrey
W164 ML350 Audi S4
On the ML the throttle pedal has started to get sticky, i.e. the tick over is to high. Simple cure stick you toe under pedal and lift it up, not ideal.
Should I lubricate the pivot ? got to be careful as I can see the fly by wire cables, which must be avoided.
Any ideas?
Bobby Dazzler
MB Club Veteran
Mittel England
ML AMG-line Black Series
It's a service part (additional item) on the W163, done every few years. I suspect it's often overlooked once out of the franchise dealer network.
OP
OP
nigel cross
nigel cross
Surrey
W164 ML350 Audi S4
What do you mean? change the throttle pedal or just lubricate it?
Auto-mobile
Birmingham
2x c43 Amg clio 172 turbo 314bhp
You could try wd40 on the hinged part, or grease the pin that holds it together.
OP
OP
nigel cross
nigel cross
Surrey
W164 ML350 Audi S4
Looked at the blog and the pedal shown is different to mine,
Mine is a W164 with the sports pedals
Bobby Dazzler
MB Club Veteran
Mittel England
Sorry, I read "throttle pedal" and "ML" and joined up dots which weren't there - sorry!!
