still having air con probs w124
michaelk3289
Work in Bristol, Live near Bridgwater
2007 W211 E280 CDI Avantgarde
hi there
not sure if this is the correct section, cant seem to find anything for aircon
i am still having probs with my aircon, i have been told that i have aircon over climate control as i have three vertical buttons in between the 2 round dials
i have several problems, the first is in regards to temp, the temp is only cold on the very lowest setting, once it is moved 1 notch up from the very coolest setting (18) it gets hot, very hot
the second is the that when it rains the car steams up on the inside, i have an air drying button but this seems to do very little, i have found an aircon dryer on ebay, will this fix the steaming up pronblem, here the link
eBay - The UK's Online Marketplace
many thanks
michael
carat 3.6
In the workshop
S124 E300d wagon, W124 om606 monster, E46 v8 coupe
I dont think you have climate control, only air con. Dose your car use any water? I ask because those may be syptoms of a leaking heater matrix. :eek:
OP
OP
michaelk3289
michaelk3289
hi there, sorry i must not have made it clear, thats correct i also believe it to be air con and not climate control, several members have also confirmed this
as far as i know the car does not use water, i have had it for several months and not found any probs with over heating etc, however i will check this
thanks for the advise
Michael
