omega1
Hi all,
I am planning on adding a little additional feature to my C220 (CDI Avantgarde SE) which will disable the electrics to the engine as part of an 'extra' to the standard alarm/inmobiliser. I have no problem in designing and installing the device but need to find a suitable cable/fuse/circuit to disable without causing any damage, preferably just a (low current) supply somewhere which will shut the engine off if the circuit is broken.
My question is, which circuit can I safely break without causing any damage to the engine? As mentioned, I am quite happy designing and installing the circuit I want, but do not really know enough about automotive electrics to know what can be done to cut off the engine...
Can anyone help?
Thanks in advance.
Can anyone help?
Thanks in advance.
