chesterpiglet
- Oct 8, 2008
- Mercedes W211 E280 Cdi Sport Estate
Hi all. I just went to clean the dash etc & need some advice for how to get rid of maybe 1mm worth of greasy grime on some of the plastic & vinyl dash parts. The photo shows what I'm up against- it is totally
gross. Normal vinyl cleaner has little effect. I spent a few minutes with T-Cut & that did get it off but it was hard word as it keeps smearing(it's like the residue when you peel a sticky label off). I need something to dissolve the grease without harming the plastic or vinyl. I use thinners on glass but suspect that would be too strong. Any suggestions please. Many thanks Rob
