Gatsby22
- Dec 27, 2018
- Location
- Walsall
- 280sl w113, 300ce w124, Morgan 4/4, BMW 420d convertible
Hello all, my first post. I am the proud owner of a 1990 300ce in very tidy condition, which I have owned for 2 years without problem. Until now that is. Despite charging the battery every few weeks through winter in the garage, the battery went flat. The usual then happened when charged and connected, of setting alarm. The key fob turned off the alarm but left the nearside indicators stuck on. No amount of opening and closing will turn them off. The only way is to disconnect battery. It is not a combination relay fault as they stay on when it is removed.
I have read somewhere that the Scorpion 918 alarm has relays inside, one of which may be stuck. However after looking under passenger carpet, behind glovebox, all around boot, under rear seats, under drivers carpets and all around engine bay, I cannot find the control unit for the alarm. This only leaves behind the instruments and who in their right mind would put it there given the amount of space elsewhere
Any help with this would be greatly appreciated. Thanks
