EuroCarParts
Cooling System Preparation for the summer.
Hi guys,
Since the winter, and the cold weather is out of the way, I’d thought we’d see what preparation you are considering for your cooling system. Below are some of our Top Tips to do before spring.
1) CHECK YOUR LEVELS
Its easy to say, and takes less than 45 seconds, but many people don’t do it! Simply check the min/max levels (the fluid should be in-between) for a bit of peace of mind. To go one step further, you should use a Hydrometer to measure the strength of your antifreeze, and thus the protection you have!
Star Buy!
Top Tech Glass Tech Antifreeze Tester
Part No: 549777561
Web Price: £2.99
Forum Price: £2.25
2) GO FOR A FLUSH
If you decide to go for a annual coolant service, make sure you use a good system flush, to clear any deposits. Remember to use a high quality coolant, to ensure maximum protection.
Star Buy!
Normfest CC442 Radiator Flush 500ml
Part No.: NOR2897363
Web Price £9.67
Forum Price: £7.25
TRIPLE QX Red Anti Freeze 5Ltr – Meets Latest G12+ Spec
Part No.: 523770481
Web Price £17.59
Forum Price: £13.20 (that's only £2.63 per litre)
TRIPLE QX Blue Anti Freeze 5Ltr
Part No.: 523770471
Web Price: £15.79
Forum Price: £11.85 (that's only £2.36 per litre)
3) Don’t wait for a leak – BE PREPARED!
Normfest have produced an AMAZING product simply called CX101 – This amazing product is tried, tested and USED by the RAC – Infact EVERY SINGLE patrol van in the UK now carries this. Most Radiator stop leaks need to be filled after a leak has occurred, with CX101 you can top it up, as the same time as your refill, and be safe in the knowledge, that if there was a leak – CX101 will seal it immediately!
Star Buy!
Normfest CX101 Cooling System Additive 300ml
Part No.: NOR2897362
Web Price: £5.99
Forum Price: £4.49
Hi guys,
Star Buy!
Part No: 549777561
Web Price: £2.99
Forum Price: £2.25
2) GO FOR A FLUSH
Star Buy!
Web Price £9.67
Forum Price: £7.25
Part No.: 523770481
Web Price £17.59
Part No.: 523770471
Web Price: £15.79
Star Buy!
Web Price: £5.99
Forum Price: £4.49
