I am afraid you will need to go down the repair route now.No, it was working if I touched sensor to sensor but not from further away so I cleaned the sensors and now won’t work at all [emoji3]
Maybe he has damaged the ‘lens’ with his cleaner... possibly stopping any IR transmission through it
Good luck Daryl, hopefully you get it fixed...Hi Abs, you right, I’ll clean it again with something else, obviously I don’t need to re-solder it when all I did was clean the sensor [emoji3]
Have you taken out the sensor to see whether its just intermittent - like mine was?Hi Abs, you right, I’ll clean it again with something else, obviously I don’t need to re-solder it when all I did was clean the sensor [emoji3]
It seems strange that just cleaning it has broken it, doesn't seem logical if you've not disturbed the sensor circuit itself.
Given the simplicity of the repair job, it might be prudent to just whip the unit out and repair it, its such a simple job.Probably is just intermittent, but I hadn’t opened/closed the door or caused any vibration in between it working and not working, so a bit strange really.
Are the sensors on the door and the IR sensor at the end of the key in good condition? without any scratches, cracks or chips?
I liked the way if one held the Recirc button on the climate control the windows would all close, then hold the button again and they would open again to their previous open positions. Worked on the sunroof as well...
Just watched the video. 3 guesses what I'm doing this weekend
Seems key fobs batteries are now a service item (mine was supposedly replaced at the last service).Hi there. I’ve just bought a 2003 E500 w211. Real beauty in mint condition. Only issue is door fobs and sensors. Changed batteries in key fob. Works sometimes up close. Sometimes not at all. Different distances on doors. Sun has come out and a day in the sun and it all works fine. Could it be the door sensors ?
... And Mrs Edd1968's now repaired and working
View attachment 85445 View attachment 85446 View attachment 85447
