Doodle
Totally agree! My z1000 weighs in at around 230kgs fully fuelled.....
Pah...lightweight! The GSA is nearly 260
Makes the old R100 feel like a bicycle in comparison, even though it's made from pig-iron.
Two feet down - not a bad thing - probably means biker is in neutral and waiting for lights to change etc. Check brake light - if its on then biker is holding bike on front brake.
Filtering - quite legal if done sensibly
The behaviour I was refering to would be better described as weaving than filtering. Changing from outside to inside to outside in moving traffic (which is accelerating or decelerating as well) and leaving no room for error isn't safe. I watched a bike almost get run down by a car after he/she slowed down crossed in front and then didn't accelerate out of the way in time - probably a missed/wrong gear.
Maybe things have changed but when I went through training the mantra was to keep the right foot on the brake.
And taking off with both legs trailing meant moving off with some loss of control (and I see a lot of foot trailers don't recover their feet to the pegs until they have moved quite a distance).
As said elsewhere esp. two up the argument might be that two feet down is more stable when stationary. However again I was taught that it's better to keep bike leaned away from oncoming traffic and that keeping it upright meant it could go in either direction - whereas resting to one side was more stable.
quote]
I've tried to teach myself to have foot on brake at the light but in my experience the risk massively outweighs the benefit.
the risk for me - out of every few hundred stops there wil be one that I dont have time to double check the gear at the stop line and/or miss the neutral light flash on the way down through the gears and therefore try to pull away in second. a mistimed throttle response and you've stalled at the front of traffic just when you should be getting out the way.
the benefit (?) - allegedly added brake power should you get rear ended - but i dont think the addition of one brake is going to help much in a bad rear end shunt and front should be enough in a nudge (all presuming you didnt see the guy coming and move off ) - thankfully I havnt had the opportunity to test my theory.
and yes quite agree with the weaving and antics. perhaps unfairly bad bikers drag us all down with them (reputation wise) bad car drivers are allocated groups by job or vehicle. ie its always i got cut up by a biker or got cut up by white van man, Beemer, taxi etc etc.
That will be the born again brigade no doubt, easily spotted by the 6 month tax disc.I would comment that bikers seem in general to have gone down a notch in the last 10 years. I notice more minor and major stupidities and less discipline than there used to be on larger bikes.
Scooters make more sense particularly the twist and go type for city areas.
My scooter weighs in at 244kg dry weight
Back brakes often dont do a lot on modern bikes now - to the point of hardly being of any use other to shift balance a little and steady a head shake.
When I took my first tuition on bikes (>30 years ago ) the teaching was the same as you mention, i.e. foot on back brake pedal and lean the bike away from oncoming traffic. Back then, most bigger bikes weighed in the region of 180kg. The Suzuki GT750 kettle was a real porker at 225kg.As said elsewhere esp. two up the argument might be that two feet down is more stable when stationary. However again I was taught that it's better to keep bike leaned away from oncoming traffic and that keeping it upright meant it could go in either direction - whereas resting to one side was more stable.
Far more idiot car drivers than bike riders imo
You could post and post about stupid things car drivers do each day there are even whole websites dedicated to complaining about bad driving we are desensitised to it , see it from a couple of bike riders and its something new
Thats tosh mate
You can stop quicker using just the back brake on a modern sportsbike than a Harley Sportster can with both
The training probably needs to be brought up to date imo.
Actually a sportsters rear brake disk is probably bigger and better than my Busas rear was.
