This basically means the due to its higher octane number it is more resistant to "detonation" which takes place within the engine whenever you depress your accelerator.
I've heard that this benefits performance/forced induction engines (basically engines which have more than the average stress on it).
The reasoning behind it is that when you ask for power, the more resistant to detonation the fuel is, the less unburnt fuel you will waste if you happen to lift off your foot from the accelerator very quickly. In Naturally aspirated cars that aren't built for performance in anyway (a completely unstressed engine) this isn't required, as they usually have a lower compression ratio within the cylinders than when compared with an engine built for performance, or has a forced induction structure to it.
I read this somewhere on a chemistry blog though, i could be a bit out.
Please what are the advantages of super unleaded fuel over normal unleaded.....Its time to consider what I am getting after many years of using super unleaded in all cars I've owned.
If the car isn't pinking, You will not see any benefit from running superunleaded. If you have advanced the ignition and/or upped the boost (run performance chips) then it will stop this pre-detonation occurring.
Now, if we see that in a car, especially a car that alters the timing to suit the engines condition then you will increase the mileage AND increase the performance in one fail swoop.
In the Merc, I don't feel any performance benefit (It is a lowly 65hp/ litre mind you) but I do feel a benefit in economy and hot idle quality.
Does the 500E use a knock sensor to set the timing or is it fixed.?
Your description is bang on and contains vital information. Only vehicles that automatically advance the timing to the point of pinking will have gains running on higher octane fuels.
The ECU advances the timing until detonation is just started then retards it slightly.
An engine where the timing is fixed Will not noticeably benefit from a higher octane fuel.
Do many of the mercs use advanced timing. W202 for example? I always put the good stuff in mine and it does seem to improve things, however this may just be my mind justifying the extra money i spend!
Cheers
