Supercharger belt length
Discussion in 'AMG Lounge' started by jamiet1986, Dec 28, 2017.
  1. jamiet1986
    jamiet1986 Active Member
    151
    Mar 9, 2013
    Car:
    w211 E55 AMG,
    my current supercharger belt is K080545HD I’m adding a 83mm pulley up top so would ideally like a smaller belt what number is the length?
    Jamie
  2. merc85
    merc85 MB Enthusiast
    7,870
    Apr 23, 2013
    Harwich
    Car:
    s211 e55k
    [​IMG]
    8PK1345 /50 Just done mine alone with the pulley's
    french likes this.
  3. Cyclone1
    Cyclone1 MB Enthusiast
    1,962
    Jun 6, 2009
    Nottingham
    Car:
    W218 CLS63 AMG
    I think I ran an 8PK1275 on the 83mm pulley and 8PK1255 on the 77mm pulley.
  4. Cyclone1
    1,962
    Jun 6, 2009
    Nottingham
    Car:
    W218 CLS63 AMG
    EBay 222748535955
  5. merc85
    7,870
    Apr 23, 2013
    Harwich
    Car:
    s211 e55k
    Oh i have a BWk i forgot sorry,
    Cyclone1 likes this.
  6. SMed08
    SMed08 Active Member
    294
    Nov 7, 2016
    Milton Keynes
    Car:
    E55k AMG
  7. SMed08
    294
    Nov 7, 2016
    Milton Keynes
    Car:
    E55k AMG
    I've got the 496HD on now with stock crank, and 84mm upper and no belt wrap kit. It's tight, but fits.
  8. OP
    OP
    jamiet1986
    151
    Mar 9, 2013
    Car:
    w211 E55 AMG,
    Sorry I should have said I have a belt wrap and 172mm crank pulley already fitted
  9. OP
    OP
    jamiet1986
    151
    Mar 9, 2013
    Car:
    w211 E55 AMG,
    I have belt wrap to are you on standard crank?
  10. AMGeed
    AMGeed Hardcore MB Enthusiast
    12,813
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2014 E63 Biturbo
    Any reason you guys are running a BWK?
    There doesn't seem to be much love for them over the pond.
  11. merc85
    7,870
    Apr 23, 2013
    Harwich
    Car:
    s211 e55k
    Yes standard crank pulley bud, my BWK was on there wen I bought it, Brutus is far from std. it’s meant stop belt slip which tbf I think it does as there is no screech from the car wen you hit boost.
    AMGeed likes this.
  12. OP
    OP
    jamiet1986
    151
    Mar 9, 2013
    Car:
    w211 E55 AMG,
    I love my belt wrap it has dramatically decreased belt slip. Also if you change supercharger pulley you are decreasing the surface area in which the belt is in contact with so slip gets worse. Had my belt wrap 4 years and it does exactly what its meant to.
    AMGeed likes this.
  13. Cyclone1
    1,962
    Jun 6, 2009
    Nottingham
    Car:
    W218 CLS63 AMG
    I ran a 77mm pulley and never had any issues with belt slip. It is important though that the correct size belt is fitted.
  14. AMGeed
    12,813
    Nov 1, 2008
    Car:
    2014 E63 Biturbo
    I have read of a few instances of pulley bearings being destroyed using a BWK, but if it works for you, why not.
    IIRC Ricky had a lot of problems on his modified E55 using a BWK.
  15. OP
    OP
    jamiet1986
    151
    Mar 9, 2013
    Car:
    w211 E55 AMG,
    I can see how this could happen if the belt is to tight. It's the same as most mods it'll put more strain on something but you get a good result.
  16. Merc55k
    Merc55k Member
    43
    Nov 8, 2016
    Car:
    Cls55
    Just on this belt / pulley conversation... my eurocharged 83mm pulley is knackered after 6 months / 4K miles. It has been running a standard belt (as advised by MSL). I’m just waiting on my pulley getting back to eurocharged for their evaluation to confirm a replacement based on premature failure. However, my belt is looking a bit tired and while the pulley work is ongoing I’m looking in to new belts. I’ve been on to a dealership to source a new belt but they are telling me there are two belts listed for the SC for my car
    Sizes: 28.45 x 1289 and 21.36 x 2449
    Anyone know which one is correct?
    Or is there are any better options for an 83mm set up than standard?
    I tend to trust MSL when it comes to things like this, but I know there are other options and would like to hear others experience.
    Cheers
    Neil
  17. Cyclone1
    1,962
    Jun 6, 2009
    Nottingham
    Car:
    W218 CLS63 AMG
    1289 std belt but would honestly fit a 1275.
    Doubt your Pulley failure will be linked to your belt as your fitted belt was standard size. In what way is the pulley knackered? Noisy bearing, broken plate etc etc?
  18. Merc55k
    Merc55k Member
    43
    Nov 8, 2016
    Car:
    Cls55
    Thanks mate.
    Noisy bearing and plate done too.
    Is there a particular brand of belt you’d recommend for the 1275 version?
  19. ricky s
    ricky s MB Enthusiast
    1,463
    Feb 26, 2008
    East Sussex
    Car:
    W211 E55 & SLK r172 55
    My own very early undersized SC pulley, was replaced initially for rivet failure, several years back, (lots of early models of this pulley suffered this), my current one is also showing signs of the rivets distorting against the plate, but monitoring this as it's not broken...yet. However, I am on my 4th bearing to this SC pulley, in approx under 20K miles. I also have the BWK, (numerous people here have bemoaned the use of this kit previously), whilst my car is modified to a level not far from your own, my car /has/is relatively trouble free, but this kit has been a PITA from nearly day one, and has been previously recorded here on a couple of occasions by myself, one of the tensioner pulleys broke its back coming home with a group here from Spa last year, destroyed the wheel, bearing and shreaded the belt..Ugh! manage to crawl home from Folkstone safely. I have also repeatedly replaced the bearings to these tensioner pulleys as well, now run a different bearing to the tensioner wheels that originally supplied with this kit.
    Why this should be I do not fully know, half of me thinks it may well be an under sized belt creating to much tension to the bearings, possibly..! but I also have half a mind that every thing may be working beyond their parameters, I also have the Kleemann crank pully, my SC pully is 84 or 83mm, cannot recall exactly, my belt I am running is the gates KO80537, this is the belt Shardul in the US supplied with the original BWK, to weather its a correct size, uhm..be good to have others input here to this. I would add, once this kit fails again, and I then have no replacement parts, I will remove the BWK, and run without it, it looks sexy on the car, but not worth the hassle it has brought me. Will be good to hear what belt you decide to run with.
    R.
    Merc55k likes this.
  20. Cyclone1
    1,962
    Jun 6, 2009
    Nottingham
    Car:
    W218 CLS63 AMG
    I used a Contitech Belt
    Merc55k likes this.
Share This Page
