I don't have any at all?have mb engineered it out?
Where exactly do you spray?
This is to cure the 'chirp', it is sprayed in the small gap between the supercharger pulley plate and the main supercharger clutch pate.
Going to put my head above the parapet here, so please dont shoot..
1) I like the chirp. A lovely little noise, as out of place as a sweet hiccup from a charging rhino.
2) A question from a non-engineer (and sorry to butt into the thread); I thought one of the advantages of a s/c over a turbo was the fact the s/c was always engaged, hence no lag. I'm not conscious of any lag in my 55k, but if it only engages at, say 2000rpm or under certain loads (when i hear the chirp) then why doesn't it give the same lag effect as a turbo?
I'm genuinely curious, and wouldn't ask if I thought I'd get laughed off the forum
Not sure if this is right Simon, you don't want to be lubricating mating clutch surfaces, otherwise it will slip, but I could be wrong
I think any chirp is when the magnet is energised, and the time it takes to fully engage... ie initial contact, worn pulley plates possibly or weak or worn pulley springs
Applying lubricant anything in this area, is like applying a lubricant on your brake disks. Its not a great design this clutch / pulley mechanism , and unfortunately noise comes with the operation.
I hear what you are saying Billy and lubricating between the surfaces seems a little odd, but this seems to be the known common fix for the 'chirp'. When I say fix I'm sure it wouldn't be permanent but.......
There are quite a few threads on the other forums on this which I searched when mine started doing it. As usual with me I was thinking there was something drastically wrong, but it turns out most of the 55K's do it and it didn't bother me so I never attempted this. The chirp disappeared when I had the Eurocharged smaller s/c pulley fitted.
Cheers, BillyCR, appreciated. I have seen that before when searching. It says "Superchargers have no lag time because they are driven directly by the crankshaft." That is where my curiosity lies - the use of a clutch as previously mentioned in the thread. Is the s/c not compressing air until the clutch is engaged ? If so, why no lag? Bear with me here, I'm not being deliberately antagonistic!
