Swapping to a 6CD multi player
ICarr
MB C220 CDI Sport
I have recently bought a 2012 CDI 220 sport that has a single cd player in it, because my last one had a multiplayer in it I'm thinking of swapping it. I have a few queries over what to do:
How do I find out if I can swap it?
If so how do I find the part number
If I was thinking of getting a DAB radio, do I need the autochanger unit and should I do it all at the same time.
How easy is it to change the unit, and is it something I could do myself?
I hope there are some techies out there that understand what I am trying to do!?
You need the autochanger unit to have any of the fibre optic based options, such as Harmon Kardon, DAB, Media Interface
Changing the unit is relatively easy (make sure you get the PIN code for the replacememnt unit assuming you are buying a used unit, pretty sure Audio-20 NTG4.5 needs a PIN code, and get your PIN code from your dealer before you change over)
Cheers
Richard
https://www.commandonline.co.uk/
Thanks for advice, I will visit that site
