Hi, has anyone fitted a 4.7k Ohm resistor to their inlet port shutoff motor comnection, it fools the ECU into thinking its working ok when it fails, so instead of replacing the motor for £££ you jus add a resistor for 5p
When the motor fails the flap defaults to its normal position which is open ( unless it's jammed) all you have to do is fit the resistor and car works fine (maybe clear codes aswel)
From what I've read all the swirl motor does is change the airflow from laminer to turbulent flow which aids combustion because air is mixed better with fuel. How it works sounds like a load of rubbish to me and it's not really necessary, causes more problems than it's worth in my opinion.
I'm going to give it a try on mine and see what happens S320
