- Mar 11, 2013
- Location
- South Bucks
- CLS63 SB, ML63, CLK350 'Vert, Triumph Sprint (Bike not Dolly...),
As part of sorting out the remote central locking on my '94 R129, I needed to know how to synchronise the infra-red key fob to the car. I found four different options (and if anyone has any more, please add them):
Method One: (THIS WORKED ON MINE)
Point the transmitter at any door/boot lock with the external LED unit and press the button.
Put the key in the ignition lock and turn it to position 2 within 30 seconds.
Method Two:
Point the remote at the lock at a distance of about 12 inches. Press button for 5 seconds.
Unlock the door by turning the key in the lock. Wait 10 seconds then remove the key.
Lock the door with the key. Wait 10 seconds and remove the key.
Method Three:
Aim transmitter at drivers door LED unit. Press button for 5 seconds. Unlock passenger door with flip-out key.
Method Four:
Lock passenger door manually with key. Go back to driver’s door, point fob at driver’s door sensor, press for 5secs. Unlock passenger door manually.
I hope this helps others. Mods, you might like to consider making it a sticky.
Method Two:
Method Three:
Method Four:
