I thought I'd test this claim out on my 120k BMW 740i V8 M60 an engine known for oil leaks and bore wear.
I refilled with a mix of Mobil 1 10W40 and Mobil 1 15W50 both fully synthetic blended to be close to Castrol GTX 15W40 high mileage mineral oil.
Four leaks started almost straight away,both sides of the cam covers dripping straight onto the exhaust down pipes...very noticeable.Left side of the oil sump and a slight weep from the crankshaft pully seal.The inside of the V underneath the intake manifold also started to fill with oil which over time will work it's way into the rear spark plugs holes.Over night perhaps 4 or 5 seperate patches will be left on my drive.
After 500 miles I refilled with Castrol and all leaks have stopped.I also noticed that slight tapping you typically get with hydraulic tappets and synthetic oil when first started went away.I changed again after 500 miles with the saved Mobil and the leaks started again.
On my 100k C180 97 I have been using fully synthetic.It has the common oil weep on the front left of the head gasket where the timing chain runs however the undertray catches it so it's of no concern.With mineral oil the seep is slightly less.The use of synthetic in this application clearly outweighs the leak.
Conclusion....on higher mileage cars synthetic oil will find out any older gaskets and may leak even if it is the same viscosity as mineral oil. There are plenty of threads on the US BMW forums to back up my findings.
adam
adam
