From the edge of tailgate to C 32mm, C-2 12mm, 2-5 5mm, 5-0 6mm and 0-d 9mm
The base of each character is 22mm up from the chrome strip.
A fresh badge on its carrier strip will be correctly spaced. Dewax the area apply a strip of masking tape to align the bottom ( I have 24mm tape in my collection of bits so it would overlap the chrome strip by 2mm). Apply a strip of masking tape so its edge is 32mm from the centre of the left side of the C and your areas all marked out. The C curved so to be factory finish the alignment needs to be its mid point.
If you are reusing an old badge without sticky on the back look on eBay for 3M double sided tape. Cut the tape to fit the back of the characters . Once stuck with this they will stay on. To remove characters I have used dental floss to cut through the sticky tape then tar solvent/ Isopropyl alcohol to clean off the gum residue.
Have fun a simple job but most rewarding when you get it spot on.
