Tape around pipe?
jryans10
Bristol
Mercedes-Benz A140
Hi everyone,
I've just noticed this tape around a pipe under my bonnett in my Mercedes-Benz A140 (2000). Any idea's what it is and how much it would cost to fix and is it anything to worry about? I can only presume that there must be a hole or something.
I have circled it:
Thanks!
carat 3.6
In the workshop
S124 E300d wagon, W124 om606 monster, E46 v8 coupe
That pipe is the fresh air feed to the air filter, nothing to worry about and it wont cause you any problems. :)
goldenii68
London
c230 elegance selection kompressor
You guess right, not sure if Euro Car Parts or similar would do a replacement, if not either a MB breakers or dealer, hopefully it wont be too expensive to replace
goldenii68
London
I forgot about Ebay:doh:
Satch
Surrey
S211 E320Cdi Avantgarde Estate & Toyota Land Cruiser
Unless it really grates, forget about it, no more than a fix for a bit of cracked plastic.
I would take the fact that somebody has actually bothered to find and fix as a good sign
removed
Guest
It's a common thing, apparently - both my A190 and A160 had this air intake hose broken and in exactly same place. I bought a new one for A190 for $30 in Nassau from local MB, but decided to use tape for A160, unless I can find a very cheap replacement. When I took the [newly acquired] A160 to PCS, Olly said there's nothing to worry about, and that's all I need to know :thumb: The hose was not even fixed then, now it looks like yours, although I used a stronger tape rated up to 80ºC, if you believe the label :cool:
removed
Guest
It's about £7 from the dealer .
Thanks Howard,
It's really weird, that in Nassau I thought $30 was a bargain yet here I would NOT pay £19 for this part ... :dk:
Found and ordered it last night from the same place you recommend, after checking part numbers on one of those Russian sites :thumb:
OP
OP
J
jryans10
Bristol
Mercedes-Benz A140
Thanks. How would I go abouts fitting this, or will I need to get a mechanic to do it for me?
Thanks,
- John.
removed
Guest
No, it's very simple:
a. unclip (by pushing slightly upwards) pipe socket and pull it out;
b. pull back the air intake hose from the socket, then it'll come off of the air filter box
done :)
Here's a diagram.
removed
Guest
CORRECTION: to unclip the pipe socket push the top of it slightly down, then pull out :thumb:
