Hello, I am aware there are some other threads for this, but none seem to come to a collective opinion.
I have a 2013 Edition 125 C63, it has 69,000 miles and full service history. I bought it just over 3 months ago, and since then, on 3 occasions it has made a loud tapping / ticking sound on cold start (see below linked video), but only until it is up to operating temperature (where the noise goes away). The tapping does indeed follow the engine RPM, but like I said, has only happened on 3 cold starts out of over 100, as I daily drive the car. I have heard that the hydraulic tappets / lifters on these engines are a common fault, so this seems most likely, but I have seen many others mention camshaft adjusters as an option as well. My main concerns with this are, will it damage the engine internals if i leave it until the problem gets worse, and is easier to take for diagnosis at a garage? Has anyone changed the lifters themselves, is it possible? I have already added hydraulic lifter additive and changed the oil to 5w. Mercedes quoted me £3000 to replace all 32.
Tapping
Second issue is a rattle on start-up, this happens much more often, around 6/10 start-ups (hot or cold). It sounds like a chain rattle maybe (see below linked video, you may need to listen carefully), for a split second on start, but you never hear anything after that. I have seen similar threads opened and a whole range of suggestions thrown around, from the chain tensioner, camshaft tensioner, camshaft adjusters to even the air con compressor (and mine is actually broken, awaiting replacement at the moment). None of those threads seem to include any videos or sound clips of the rattle itself, hence why I thought starting a new one and including that could be useful. I have similar concerns regarding this issue (potential damage, ease of DIY).
Rattle
If anyone has experienced any of this or knows anything that might be useful I would love to hear about it. I appreciate your time.
Tapping
Rattle
