Technical Service Bulletins from Alldata
Satch
Surrey
S211 E320Cdi Avantgarde Estate & Toyota Land Cruiser
Anybody tried this service? Costs about US$25 per vehicle and could be useful for some.
http://www.alldata.com/products/diy/index.html
Example: W211 E55 AMG:
Bulletins for 2003 Mercedes Benz E 55 AMG (211.076) V8-5439cc 5.5L SOHC SC (113.990)
Safety Recalls
TSB Number Issue Date TSB Title
2003080003 AUG 03 Recall - Steering Coupler Pinch Bolt Torque
General Recalls
2003020003 JUN 03 Campaign - Front Door Module Replacement
2002090005 DEC 02 Campaign - Instrument Cluster Module Flashing
Service Bulletins
P-82_10-343A APR 04 Lighting - Fog Lamp Beam Screen Cap Loose
P-82_10-344 APR 04 Lighting - Left/Right Brake Lamp Brightness Difference
P-54_00-71C APR 04 SRS - MIL ON/Multiple DTC's Found
P-67_29-10 APR 04 A/C - Rear Window Won't Heat in the Upper Area
P-82_70-346 APR 04 Cellular Phone - V60s Phone Locks Up
P-82_60-259A APR 04 BCM - P9386 Control Module Diagnosis Stored in DAS
P-82_85-325B APR 04 Audio - Intermittently Not Functioning
P-46_20-16 APR 04 Steering - Leaks at Line/Rack Housing Connection
P-42_46-38 APR 04 Brakes - Software Patch Necessary Before Bleeding System
P-82_95-322A APR 04 Communications - 'Tele Aid Not Active' Displayed
P-82_85-322 APR 04 Navigation System - Installation
P-82_20-336 MAR 04 Interior - Sliding Roof Switch Cover Cracks
P-82_70-338 MAR 04 Cellular Phone - Poor Hands Free Usage Quality
P-82_85-332 MAR 04 Navigation System - Slow to Start Upon DVD Insertion
P-42_20-35 MAR 04 Parktronic System(R) - Intermittently Inoperative
P-46_10-15 MAR 04 Interior - Steering Wheel Heater Inoperative
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-54_18-108 FEB 04 Starting System - Engine Does Not Start
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
P-82_85-301 FEB 04 Navigation System - DTC D300 Explanation
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-42_46-32A JAN 04 Brakes - Whistling Noise When Depressing Brake Pedal
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-54_21-89B JAN 04 Charging System - 'Battery: Visit Workshop' Message
P-54_65-104A JAN 04 Parking Assist System - Triggers for No Reason
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
P-30_20-61 DEC 03 Engine Controls - MIL ON/Limp Home Mode/DTC's Set
P-54_10-106 DEC 03 Battery/Charging - Error Message Displayed/DTC's Set
P-42_46-27C DEC 03 Brakes - Buzzing Noise During SBC Pressure Build-up
P-82_30-316 DEC 03 Wipers/Washers - Erratic Intermittent Wipe Explanation
P-82_10-258A DEC 03 Lighting - Front Turn Signal Lamps Inoperative
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
P-82_95-295 OCT 03 Communication Platform - Mobile Identification Number
P-82_62-226A OCT 03 Audio System - Intermittent Loss of Audio
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-88_50-33 SEP 03 Body - Trunk Lid Springs Back When Opened
P-54_18-98 SEP 03 Battery - Disconnecting Requirements During Vehicle Svc.
P-82_10-255 AUG 03 Lighting - Premature Headlamp Bulb Failure
P-88_50-32 AUG 03 Body - Water Drips Into trunk With Trunk Lid Open
P-61_10-02 AUG 03 Body - Water leaks Into Trunk
P-54_10-90 AUG 03 Battery - Diagnostic Troubleshooting procedure
P-82_00-260 JUL 03 Audio System - Dual Sided CD's Won't Eject
P-82_95-273 JUL 03 Communications Platform - DTC D640 Set
P-82_95-274 JUL 03 Communications Platform - DTC D662 Set
P-82_10-269A JUL 03 High Mount Stop Lamp - Water Leaks Into Trunk
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
P-82_95-251A JUL 03 TeleAid(R) System - 'TeleAid Defective' Displayed
P-82_95-267 JUL 03 Cell Phone - Erroneous Hands Free Fault Code
P-14_30-15 JUL 03 Emissions - MIL ON/DTC P2003 Stored in Memory
P-82_10-257 JUN 03 Lighting - Headlamp Bulbs Inoperative
P-82_95-235A JUN 03 Communications Platform - Replacement Instructions
P-82_30-254 JUN 03 Wipers/Washers - Wiper Blades Noisy
P-82_95-250 MAY 03 TeleAid(R) System - No Audio Mute When Button is Pressed
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-82_95-242 APR 03 Communications Platform - DTC D003 Explanation
P-62_00-03B APR 03 Electrical System - Various Malfunctions
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-32_22-15 MAR 03 Air Suspension - Low Ride Height in Cold Temperatures
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
P-54_18-84 MAR 03 Battery - Disconnecting During Service
S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
P-82_60-227 FEB 03 Audio System - Static Noise With Rear Defroster ON
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-46_20-10 FEB 03 Steering Rack - Connector Leaks
P-77_20-19 FEB 03 Moonroof - Intermittent Synchronization Loss
P-54_21-80 JAN 03 Electrical - Rear Fuse Panel Cover Difficult to Remove
P-54_15-79 JAN 03 Electrical - Wheel Well Fuse Box Loose
P-82_10-218 JAN 03 Lighting - Dust/Debris Inside Tail lamps
P-54_10-78 JAN 03 Electrical - Automatic Switching ON/OFF Explanation
P-82_60-214 DEC 02 Audio System - No/Poor FM Reception
P-83_55-65 DEC 02 A/C - Compressor Cycles Frequently
P-80_61-17 NOV 02 Keyless Go System(R) - System Initialization
P-54_21-74 NOV 02 Engine Controls - ECM Programming Procedure
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
P-72_10-28 OCT 02 Power Locks - Lock Knob Jumps Up and Down
P-62_25-04 OCT 02 A/C - Water Entry Into Footwell/Electrical Malfunctions
P-82_95-206 OCT 02 Communications Platform -Tele Aid DTC Codes
S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
P-18_00-17A JUL 02 Engine - Approved Engine Oils
S-07_08-001 JUL 02 Engine Controls - Software Calibration Number Coding
You can get this info for free from DC HQ in Milton Keynes. I rang them a few years ago about my own car and they asked me for the VIN - fired it through a database and it came back with nothing. I asked about the airbag recall and they said my car wasn't in the range of VINs affected.
Remember that in the UK there is no legal requirement to recall vehicles, and the yanks are quick to do it because of litigation and the "lemon laws".
Got a w202 with a creaky seat frame? Recall in the USA - UK they make you buy a new seat frame.
On the same vein (but not very MB oriented), one of the reasons I now own an MB instead of a BMW:
Known problem with their dashboard control module (all sorts of wierd behaviour and failures): In the USA, BMW North America actually monitor the BMW forums and step in with a free replacement to anybody reporing a problem (any age of vehicle). When mine failed, BMW UK said it was not a known problem (and it costs £600+ to replace). Funny how the dealer knew all about it, though....
Well, no doubt the Lurkers and Trolls from DC UK and Dealerships will be delighted with this thread then :D
