- Sep 16, 2004
- Location
- Leven, Fife / Northampton
- 2006 320 CDI Avantgarde . 1997 312d Sprinter
Hi, vehicle is 1997 300TD , I recently did a 400 mile journey up to Scotland and almost there I noticed the temperature gauge falling from its normal centre 80 degrees position down to about 50/60 degrees. Because I was so far from home I just monitored the situation and did nothing as there was no immediate problem.
I just did the same 400 mile journey home, the engine ran faultless purring away at about 2500 RPM. @ 75 mph and the gauge is still reading low. There seems to be nothing else wrong with the car.
So is this an engine temperature sender fault?? and if so where can I find the engine temperature sender, I have looked and cannot see one. Failing that, is this some other electrical fault causing a low reading.
Comments appreciated -- Thanks.
