popuptoaster
Not all LED bulbs are terrible in reflectors designed for filament bulbs, mostly just the cheap ones but the difficulty is finding a set that give a decent beam pattern and more light and have that light in the places you want it, you can spend hours on You Tube selecting the ones you want.
Any halogen bulb over the stock wattage is technically illegal anyway so having LEDs in there wouldn't bother me any more than having uprated bulbs normal would.
If your lights are really bad and the car is over ten years old then replacing the wiring can often make quite a difference if it's degraded, I have had several older cars that benefited from running new power direct from the battery via a fused relay and using the old wiring just to trigger the relay.
