Thanks for the speedy reply chaps -
I have just bolted down the head after having it reconditioned.
Its a bit of a long story but this is the second time due to problems after the first head was refitted it suffered an awful tappet problem.
The first time I re-assembled everything I put the hydraulic tappets onto a radiator for 2/3 to let the oil drain out and then popped them back in - I was told by the head recon centre to put them in a vice with wood and squeeze the oil out which I tried using a large G clamp, it seemed too hard to get the oil out this way so opted for the former.
The engine ran ok but did have this awful tappet noise so I ordered and fitted 20 new lifters - still the same no change, on measuring the gaps from tappet to adjacent tappet there was a large gap (see photo)
So, off comes the head again back to the head centre for another round of grinding and valve stem seals.
I followed the same procedure and put the lifters on a hot rad for a week turning every other day - tons of oil ebbed out onto news paper until they stopped - I have followed the re-assembly to the letter and have ensured everything is torqued up correctly but she wont fire -
Turing the crank over I can only feel compression on maybe one cylinder hence the question of how many compression stokes should you be able to feel per turn -
Ahhh...feel better now thats off my chest
So either there is oil still in the lifters keeping the valves open OR the seats which are now quite deep having been machine twice are causing the valves to protrude too high
