jgevers said:
As far as I know, both Pierburg and Bosch hot film and hot wire air mass sensors have analogue outputs. The digital sensors that come to mind are the KV type air flow meter (Mitsubishi) some Ford MAP sensors.
To test MAF sensors with a multimeter is a wast of time imo. Only an oscilloscope will show the voltage over time. In theory a 'worn' MAF sensor could still get to it's top voltage, but could take a lot longer. Most air mass sensors get to their top voltage before maximum air flow is reached. The ECU uses the other load sensors like throttle pedal position sensor to fill in the rest. This means that although the sensor gets to max. voltage, it could still be reading a lower voltage than nessesary for any given air mass.
regards,
job
You are correct re the output being analogue but it has been processed through a digital amplifier.
With an analogue MAF there is no reason why a DMM can't be used as long as the airflow is kept constant for a short period. If the vehicle is being driven in a high gear this will result anyway.
The no load tests simply require the revs to be held constant at each stage whilst a reading is taken.
These are not "scientific" tests carried out using a WOT rev on a rolling road, so timebase is not measured but isn't required. Don't forget so far all these results are for diesel engined vehicles so WOT doesn't apply.
MB dealers only test MAF outputs at idle anyway.
Obviously it would be more scientific to test the MAF in a given airflow condition, but if a comparison is drawn betwen similar engines at steady revs and load conditions, that will act as a reasonable guide.
These tests started as a comparison with known good and bad MAF sensors and so far appear to be an accurate method of determining a poor performing sensor.
I understand your thoughts regarding the sensor heating upto it's potential, but that is the problem anyway, the sensor plate is being insulated from cooling down hence the output is reduced.
The easier it is for a MAF to maintain heat the lower the air mass and so the output is lower.
Anyway, thanks for your input and feel free to disagree.
Regards
