Originally posted by sym
YES !
If you press this button with the ignition off, it will use residual heat from the engine to heat the car (only useful for cold nights when you break down and dont want to run out of petrol by running your engine while waiting for the emergency services !)
S.
YES !
S.
Originally posted by GrahamC230K
Simon, go back outside and see if the fan stays on after you lock the car? You may need to lower the window to tell this.
Or has yours been going for the whole hour?
Thanks!
If it will cool or heat for a timed period with car locked, this is really handy - I always read the manual - can't believe 2 w202's later I have only just found this out!
So it's timed to 30 minutes is it - or has yours been going for the whole hour?
