JoeGons
Hi, 2001 E320 W210. (European)
See picture of Control Panel.
There does not seem to be anything about my particular problem.
The Air condition quit. No Power.
For a long time the Blower has been faulty. I had planned to replace it or at least the brushes.
The speeds all worked fine.
The blower would just stop for a while and then start back. Sometimes a few seconds and sometimes an hour.
The Compressor would continue to run and I would select “EC” until the blower started up.
The little red light on the “EC” button would come on when “EC” was selected.
Last week I parked the car and the A/C was working just fine.
When I started the car some hours later, the A/C was showing no sign of life.
The compressor would not come on and the light on the “EC” switch would not come on.
I have checked all the fuses that I could find that said Blower motor A/C.
I have not been able to determine if there is a “master” fuse for the A/C.
Also, this car has a single engine cooling electric fan. No Aux fan.
That fan seems to run at full speed as soon as you start the engine.
Before I take it to the Dealer, I was hoping to give it another look.
There seems to be no power to the A/C.
I know I will have to start from the beginning with the fuses and go forward.
I am hoping someone might give me an idea that will make the journey shorter.
I am hoping that if I can restore power, it will come back to life.
I do not have access to a good code scanner and I think I would need a “Star” scanner to see all those A/C sensor readings because it is not the “Digital” (USA Push button) version that can assess the sensor values.
I also have a slow leak on the evaporator. It takes about three months to leak enough to require a top-up.
I am looking at a product called CryoSeal that has been mentioned here.
I am reluctant to add anything to the system because I have read too many warnings about additives.
I need more user experience reports.
Joe
Joe
