D
Deleted member 2227
Guest
Following on from my Complete M271 and M272 engine threads here is “The complete M276” thread.
The Mercedes-Benz M276 engine is a direct injected, V6 gasoline automotive piston engine. has a displacement of 3.5 liters (3499 cc) with a bore of 92.9 mm and stroke of 86 mm. Output is 302 hp (225 kW) at 6500 rpm with 273 ft·lbf (370 N·m) of torque at 3500-5250 rpm.
The M276 engine is related to the Chrysler Pentastar V6 engine, with which it shares its basic architecture, as it was developed while Chrysler was still owned by Daimler AG. This can be seen in its 60 degree vee-angle, as opposed to the 90 degree angle of its M272 predecessor. The 60 degree vee-angle eliminates the need for a balance shaft, improving refinement while reducing mechanical complexity.
The M276 engine features an aluminum engine block and dual overhead camshafts with independent variable valve timing on intake and exhaust valves and a new timing chain arrangement. The M276 also includes direct injection with piezo-electrically controlled injectors for more precise fuel delivery, multi-spark ignition that allows for multiple ignition events during the combustion stroke, and modified accessories (such as the fuel pump, water pump, oil pump, and alternator) that reduce parasitic loads. These features are also shared with Mercedes' M278 V8 engine, announced at the same time.
Mercedes-Benz claim that the new engine, in conjunction with vehicle modifications such as a stop-start system, can produce up to a 24% improvement in fuel economy while increasing power and torque over the M272.
Derivations.
Mercedes-Benz M 276
From Wikipedia, the free encyclopedia
Mercedes Benz
M 276
Manufacturer:
Mercedes Benz
Production period:
since 2011
Shape:
V , six-cylinder
Engines:
3.0 liters
(2996 cc)
3.5 liters
(3498 cc)
Previous model:
M 272
Successor:
M 256
Similar Models:
M 278
The Mercedes-Benz M 276 is a series of six-cylinder - V-engines ( gasoline engines ), the Mercedes-Benz since the fall of 2010 as a successor of the M-272 produced generation. Compared to its predecessor is the cylinder bank angle of 90 ° is reduced to 60 °, so that even without balance shaft no free inertial forces of the first order occur. The bore is 92.9 mm, the stroke 86 mm. The compression ratio amounts to 12.2:. 1
The engines are far more fuel-efficient than the previous types. There comes a gasoline direct injection of the third generation with lean operation, as well as a multi-firing are used.
The engine generation is closely related to the eight-cylinder M 278 , even though they have 90 ° cylinder bank angle. The new V8 is already since the end of 2010 CL-Class and S-Class used. The six-cylinder debuted in spring 2011 in the facelifted C-Class and the new SLK and CLS and all 4MATIC models.
Contents
• 1 variants
o 1.1 M 276 DE 30 AL red. *
o 1.2 M 276 DE 30 AL *
o 1.3 M 276 DE 35 red. *
o 1.4 M 276 DE 35 *
o 1.5 M 276 DE 35 AL *
• 2 Technology
• 3 sources
Variants
Initially, only aggregates came with 3.5 liters cubic capacity is used. From spring 2013 will also be a reduced in size to three-liter engine, which is charged by means of two turbochargers, offered.
Sales designation
Series
Construction period
Displacement: 2996 cc, output: 200 kW (272 hp) at 5000 / min, torque: 400 Nm at 1300-4500 / min
E 320
C / A 207
since 2014
R 320
V 251
since 2014
M 276 DE 30 AL * [ Edit ]
Sales designation
Series
Construction period
Displacement: 2996 cc, output: 245 kW (333 hp) at 5250-6000 / min, torque: 480 Nm at 1600-4000 / min
ML 400
W 166
since 2015
GL 400
X 166
since 2014
C 400
W / S 205
since 2014
E 400
C / A 207
since 2013
E 400
W / S 212
2013-2014
S 500 Plug-in Hybrid
V 222
since 2014
SL 400
R 231
since 2014
R 400
V 251
since 2014
GLE 400 Coupé
C 292
since 2015
Displacement: 2996 cc, output: 270 kW (367 hp) at 5500-6000 / min, torque: 520 Nm at 2000-4200 / min
C 450 AMG
W / S 205
from 2015
GLE 450 AMG Coupé
C 292
from 2015
M 276 DE 35 red. *
Sales designation
Series
Construction period
Displacement: 3498 cc, output: 185 kW (252 hp) at 6500 / min, torque: 340 Nm at 3500-4500 / min
ML 300 4MATIC
W 166
since 2012
E 300
E 300 BlueEFFICIENCY
C / A 207
2013-2014
2011-2013
E 300
W / S 212
2013-2014
2011-2013
CLS 300
C 218
since 2012
M 276 DE 35 * [ Edit ]
Sales designation
Series
Construction period
Displacement: 3498 cc, output: 225 kW (306 hp) at 6500 / min, torque: 370 Nm at 3500-5250 / min
ML 350
ML 350 BlueEFFICIENCY
W 166
2013-2014
2011-2013
SLK 350
SLK 350 BlueEFFICIENCY
R 172
since 2013
2011-2013
C 350
C 350 BlueEFFICIENCY
W / S / C 204
2013-2015
2011-2013
GLK 350
GLK 350 BlueEFFICIENCY
X 204
since 2013
2011-2013
E 350
E 350 BlueEFFICIENCY
C / A 207
2013-2014
2011-2013
E 350
W / S 212
2013-2014
2011-2013
E 400 HYBRID
W 212
since 2012
CLS 350
CLS 350 BlueEFFICIENCY
C / X 218
2013-2014
2011-2013
W / V 221
2011-2013
S 400 HYBRID
W / V 222
since 2013
SL 350
R 231
2012-2014
R 350 BlueEFFICIENCY
W / V 251
2012-2014
M 276 DE 35 AL * [ Edit ]
Sales designation
Series
Construction period
Displacement: 3498 cc, output: 245 kW (333 hp) at 5250-6000 / min, torque: 480 Nm at 1200-4000 / min
E 400
W / S 212
since 2014
CLS 400
C / X 218
since 2014
* The motor designation is encrypted as follows: M = engine (Otto), series = 3 digits, DE = direct fuel injection Capacity = deciliter (rounded), A = exhaust gas turbocharger, L = intercooling, red. = Derated
Technology
For technology package of the new generation of engines include, among others, some new developments. The advanced third-generation direct with spray-guided combustion and piezo injectors leads, in conjunction with a multi-firing to reduced fuel consumption - the V8 by a further developed homogeneous combustion process in the V6 by a new stratified combustion process with extended performance range including optimum fuel efficiency, lean burn. The power consumption of ancillary units has been reduced. These include an optimized water pump with second generation thermal management, a regulated oil pump, a volume-controlled high-pressure fuel pump and an intelligent generator regulation. By means of consistent lightweight design and an intense fine optimization also the engine friction has been significantly reduced compared to the previous engine. Together with the start-stop technology , shift point adjustment and the frictional loss overall improvements in driving consumption of more than 20 percent were possible.
Tuning Options
Kleemann
“The latest generation normally aspirated, direct injected, 3.5 liter M276 V6 engine, with a maximum of 306 HP and 370Nm (272 lb-ft) of torque, is a powerful and smooth mid range engine. This engine is available in the 2012+ C, CLS, E, and ML. Our R&D department has spent an enormous amount of time perfecting the ECU software for this engine. An increase in power of up to 330 HP and 400 Nm (296 lb-ft), as well as improved throttle response and raised speed limiter, is now available. As a unique KLEEMANN feature, we have managed to improve the software in the 300 models (which is, in fact, the same engine as the 350, but intentionally limited in power production by the factory) so the new power level becomes the same level as the 350, plus tuning gains. 300 owners will gain what is a normally unheard of improvement in power and torque from an ECU tuning.
350-K1(BE): ECU tuning. Up to 330 HP and 400 Nm (296 lb-ft) of torque.
300-K1(BE): ECU tuning. Up to 330 HP and 400 Nm (296 lb-ft) of torque.
300 & 350 V6 BE (M276) Archives - Kleemann
Vaith, Carlsson, MKB and Brabus all only offer remapped ECU and V Max removal. They claim roughly 330bhp and 167mph VMax….
Problems
Basically they are very good engines although some had issues with rattling or noisy timing chains on start up. The issue is to do with oil not get to the chain quickly enough and was addressed by Mercedes in the attached bulletin that tells you everything that you need to know.
The engines affected are :
Engine 157:
1) From engine number 157 9xx 60 009368 up to engine number 157 9xx 60 017984 install check valves and chain
tensioners
2) From engine number 157 9xx 60 017985 up to engine number 157 9xx 60 022333 (December 2012) install check
valves (optimized tensioners installed in this production range)
08-12-2013 1:44 AM d7recast
Engine 2768:
1) Up to engine number 276 8xx 30 000790 install check valves and chain tensioners
2) From engine number 276 8xx 30 000791 up to engine number 276 8xx 30 001281 install check valves only
Engine 2769:
1) Up to engine number 276 9xx 30 365996 install check valves and chain tensioners
2) From engine number 276 9xx 30 365997 up to engine number 276 9xx 30 406603 (February 2013) install check
valves only (optimized tensioners installed in this production range)
Engine 278:
1) Up to engine number 278 9xx 30 073273 install check valves and chain tensioners
2) From engine number 278 9xx 30 073274 up to engine number 278 9xx 30 103675 (February 2013) install check
Note:
When performing repairs and only the check valves are supposed to be installed, the tensioners must still be checked
according to WIS documentation. If optimized tensioner is found to be defective it must be replaced
This thread is the starting point for updates so please add information as you find it. HTH
Derivations.
Mercedes-Benz M 276
Mercedes Benz
M 276
Manufacturer:
Mercedes Benz
Production period:
since 2011
Shape:
V , six-cylinder
Engines:
3.0 liters
(2996 cc)
3.5 liters
(3498 cc)
Previous model:
M 272
Successor:
M 256
Similar Models:
M 278
Contents
• 1 variants
o 1.4 M 276 DE 35 *
• 2 Technology
• 3 sources
Variants
Sales designation
Series
Construction period
E 320
C / A 207
since 2014
R 320
V 251
since 2014
Sales designation
Series
Construction period
ML 400
W 166
since 2015
GL 400
X 166
since 2014
C 400
W / S 205
since 2014
E 400
C / A 207
since 2013
E 400
W / S 212
2013-2014
V 222
since 2014
SL 400
R 231
since 2014
R 400
V 251
since 2014
GLE 400 Coupé
C 292
since 2015
C 450 AMG
W / S 205
from 2015
GLE 450 AMG Coupé
C 292
from 2015
M 276 DE 35 red. *
Sales designation
Series
Construction period
ML 300 4MATIC
W 166
since 2012
E 300
C / A 207
2013-2014
2011-2013
E 300
W / S 212
2013-2014
2011-2013
CLS 300
C 218
since 2012
Sales designation
Series
Construction period
ML 350
W 166
2013-2014
2011-2013
SLK 350
R 172
since 2013
2011-2013
C 350
W / S / C 204
2013-2015
2011-2013
GLK 350
X 204
since 2013
2011-2013
E 350
C / A 207
2013-2014
2011-2013
E 350
W / S 212
2013-2014
2011-2013
E 400 HYBRID
W 212
since 2012
CLS 350
C / X 218
2013-2014
2011-2013
W / V 221
2011-2013
S 400 HYBRID
W / V 222
since 2013
SL 350
R 231
2012-2014
W / V 251
2012-2014
Sales designation
Series
Construction period
E 400
W / S 212
since 2014
CLS 400
C / X 218
since 2014
Technology
Tuning Options
Kleemann
Problems
Engine 157:
tensioners
Engine 2768:
Engine 2769:
Engine 278:
Note:
