Skd884
- Sep 13, 2017
- i3
Failed mot ?
Thats correct. The e63 produced 540hp to the wheels in the video in the US, but it is the AWD version and depending on whether you go with the correction factor of 20% in AWD or more prudent 15%, thsts a lot of HP not brought into account 60 to 100hp is a lot. I wonder if there was a more expensive AMG out at the time that would have been left looking a bit ordinary by the tune on the w212 63 s.It’s not unusual for a car to produce more power in reality than is published by the manufacturer and Mercedes/AMG are particularly generous in this respect.
They need to make sure that their cars are capable of producing their published power output regardless of fuel quality, octane rating, altitude, ambient temperature, etc.
That means that in the UK where those things are all favourable, engines tend to produce more power than is published, in some cases significantly more.
Of course when tested on a dyno the operator applies a correction factor which adjusts the output to standardise conditions and allow comparison.
Mercedes do engineer power outputs for different models using the same engine, for a variety of reasons, including creating performance and/or model distinctions and hierarchies, however they wouldn’t “understate” one model but leave the engine identical - instead they limit performance using hardware and/or software differences between models.I wonder if there was a more expensive AMG out at the time that would have been left looking a bit ordinary by the tune on the w212 63 s.
You replaced a single shock? Or both?
Yes, they're wrong. If you're running a square setup for winter the approved fitment is 255/35/19 all round. And yes, they do look a bit stretched on the rear.Had an email from MB Guildford, they say that the current winter tyres are 235/35/19 on the front and 285/30/19 on the back.
Am I correct in thinking that the fronts are too narrow?
At the moment the 285 on the rear looks stretched. I’m not sure a 255 would actually fit, is it possible I’ve got some rims from a different model that are wider? They look identical to the stock rims.Yes, they're wrong. If you're running a square setup for winter the approved fitment is 255/35/19 all round. And yes, they do look a bit stretched on the rear.
FWIW, I ran Michelin PA4's on my E63 in that size and they worked fine.
Possible, but doubtful.is it possible I’ve got some rims from a different model that are wider? They look identical to the stock rims.
For summer tyres, yes. But @Dammit is asking about winter tyre sizes.285 is oem fitment for your car on the rear, same as my c63.
