tron
In case you are not familiar with the acronym, My car is fitted with one. It arrived with a starting problem, which, once cleared moved to the EGR system and, once that had been bashed went to play in the rear SAM, evaporating the HRW fuse. Coming home, the SRS lamp came on and, following a restart, went off again only for the wipers to appear to have failed while debugging blocked screen washer plumbing. I suspect that may have been while I had the bonnet open so I shall try again later but until then, the MEG is on notice. Tron's gonna have you, Migratory Electrical Gremlin. Pack your bags!
