SavMan
On the 16th a few of us are heading up to Santa Pod for some fun on the 1/4 mile you can find details here and are welcome to join us http://www.mbclub.co.uk/forums/events/131530-santa-pod-16-06-a.html
For those that have raced the 1/4 you will know that the first 60ft is all important, so how to get a perfect launch.
I have an E55 AMG Wagon using street tyres and this is my method
Go around water!
Raise rear to 5mm above standard height, dip front end 16mm below standard.
Put suspension in comfort mode
Choose "S" setting on gearbox and manually select 1st gear
ESP on
Left foot brake
Light throttle to 1000 rpm
On Go - Lift brake and roll gently to 1/4 throttle, then progressively 1/2, 3/4 and full WOT
What's your thoughts, on my last attempt I was still struggling with traction right through the first 60ft!
Go around water!
ESP on
Left foot brake
