Black c320
Following Alex Crows suggestion about a resistor to simulate the swirl motor I decided to give it a try yesterday.
I got a 4.7k ohm resistor from Maplins for 26 pence and as it was an experiment i didn't want to cut wiring so i inserted the resistor tails into the connector pin holes in the live and signal wires on the swirl motor plug.
So i took the car for a 25 mile run of mixed roads and the car ran perfect,
no CEL no limp mode and its normal 36+ mpg.
Although this was done as an experiment i have decided to run the car as is to see how it goes long term with no swirl motor.
The swirl motor problem is a subject we have been discussing on the Chrysler 300c crd forum for a couple of years and although my swirl motor had not failed, I decided to give it a try, now we have the solution.
Another member whos swirl motor has just failed has today carried out the mod and saved the cost of the repair.
Now the mod has been proved the resistor will be installed in a more permanent fashion.
